![]() | #1 | ||
Posts: 2 Thanks: 0 Trader Rating: 0 ![]() | fault code 20502 (power steering) any ideas? power steering has packed up and fault light on. have read the codes and have C1007 - Electric motor, C1012 vehicle speed (from CAN), and 20502 which i cant find out anything about?? Anyone know this code? And what likely to be the fix? Do you think the ECU most likely rather than the electric motor itself. Any input would be great thanks Darren
![]() | #2 | ||
dotdesign Join Date: May 2010 Location: Dundalk
Posts: 1,454 Thanks: 79 Trader Rating: 0 ![]() | Re: fault code 20502 (power steering) any ideas? https://www.fiatforum.com/punto-guid...ng-column.html read that, sounds like this, "If your steering light has/is on it might not be steering column related,a faulty vehicle speed sensor (or sensor wiring) fault will bring on the light it may also bring on the engine warning light & even stop the speed from working.A error code (P0500) will be logged in either the steering ecu/fuel ecu or body computer. If this is the case a wiring modification (carried out by dealer) from the speed sensor to the fusebox can be carried out...problem sorted. It is also worthwhile checking the connectors are 'sound' on the steering ecu as there have been reported cases of loose connectors/wiring in this area."
![]() | #3 |
Posts: 16,588 Thanks: 912 Trader Rating: 0 ![]() | Re: fault code 20502 (power steering) any ideas? c1007 - Pretty Simple really, I would have thought a new motor from a scrappy should help? Ziggy
__________________ |
![]() | #4 | ||
Posts: 16,570 Thanks: 831 Trader Rating: 0 ![]() | Re: fault code 20502 (power steering) any ideas? Or a service exchange they do the motors now if the main column is ok.
![]() | Muppet1 | Stilo | 7 | 22-07-2009 00:02 |
![]() | w122ard | Stilo | 10 | 10-06-2009 18:43 |
![]() | bridges | Punto (Mk2/2b) | 0 | 07-12-2008 14:30 |
