Mk2 2001. Symptom - no start, battery flat. Fix (by owner) - new battery. Result - no better, soon went flat again! Came to me. I checked battery voltage with engine running (14V) so I think alternator is OK. Alternator belt is OK. Looked around and found a loose wire. Determined that this had broken off a bonnet switch (corrosion) then noticed an alarm horn.
This aftermarket alarm must have been fitted by a previous owner. It also provides remote central locking. As far as I can tell by looking at the siren (it says Clifford), the remote fob (it also says Clifford and has three buttons), the blue bezel-LED and a small two-push button thing, I think it is a Clifford Arrow 5.
It is powered via a couple of added in-line fuses (5A and 15A) close to the battery.
Does anyone have experience of this system on a Punto? I need to know whether it has been installed correctly and whether it is draining the battery.
red
red
