Old 08-11-2010   #1
Unhappy EOBD Light Amber Permanently
Hi there,
I have a Punto 1.2 8V 5DR 2004 model
The other day, about 3/4 through a 30 mile journey, the EOBD Light on the dashboard came on, but it didn't flash, or say 'engine failure' on the screen, it just came on permanently, unlike I've read on other threads.
The manual says that this means:
'a fault in the supply/ignition system which could cause high emissions at the exhaust, possible lack of performance, poor handling, and high consumption levels. The warning light goes off if the fault disappears'
It also says you can still drive the car if the light is on, but you should have the fault checked out.
Anyway, I finished the journey, and the next morning I got into the car, and sure enough, the warning light was still on (HUFF). I made a few short journeys that day, and on about the 4th time starting the engine that day, I noticed the light had gone off....
It stayed off for a week or so, so I thought it could have just been a random blip, and forgot about it.
But then last night, it came on again. (also at about the same point in the 30 mile trip!).
The next day, I went to go to work, and as before, the light was still on. It was also still on when I drove home from work at the end of the day.
When I pulled up at home, I turned the ignition off, then on again. Light still on.
I turned it off, then on again, Light still on....
Then I did it one more time, and VOILĄ, its turned off now...
Weird ay?
Anyone else had this problem?
Any ideas as to the cause of this would be much appreciated
Thanks,
Howard
atthedouble2 is offline Reply With Quote Quote
Old 08-11-2010   #2
Re: EOBD Light Amber Permanently
The ECU clears intermittent faults after a certain number of cycles (on/off) so it indicates you have an intermittent fault with the engine. It could be something as simple as a slightly dodgy lead, right through the whole gamut of faults. You need to get the fault read to find out what the problem is.
Scoobysnacks is offline Reply With Quote Quote
Old 11-11-2010   #3
red is offline Reply With Quote Quote
(T) EOBD dashboard light flashing amber around 70mph birdietrail Punto (Mk2/2b) 21 06-01-2016 21:41
(T) Seicento Sporting battery light on permanently ChrisC Cinquecento / Seicento 11 08-12-2007 21:56
(G) Amber Flashing light below airbag light on Punto stesand Punto (Mk2/2b) 2 28-11-2007 13:48
(T) Rear Brake light permanently out!! edknox Stilo 2 26-10-2007 15:56
(T) circle with exclamation mark light on permanently!! HGT_GIRL Punto (Mk2/2b) 15 21-12-2006 00:53
