Old 29-03-2010   #1
Starter motor problem?
Have had a problem for a while. In the mornings, starter motor has been turning over VERY slowly but car does just about start. Also, makes a noise (like when you turn the ignition when the engine is already running).
Anyway, once started its ok then for the rest of the day. So I assumed it was the batttery.
Yesterday though it wouldnt start about 10 mins after I'd just driven 30 miles. Checked the battery voltage and it was 12.75 (which is fine, yeh?)
Did eventually start. Checked this morning and battery was 12.6 (this is ok, yeh?). Still the same - started just about.
Does this sound like a starter motor problem?
How much for starter motor? Easy to fit myself?
psychocandy is offline Reply With Quote Quote
Old 29-03-2010   #2
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: Starter motor problem?
Check for poor connection of the battery to engine earth lead.
There's a guide how to do it in the Stilo Guides section but the principle is the same for the Punto and all cars.
https://www.fiatforum.com/stilo-guid...ery-earth.html
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 30-03-2010   #3
Quote Originally Posted by Davren View Post
Thanks. I'll try that. Battery is at 12.6v so its ok. Also checked when running and its 14v+ so thats ok too.
Old 30-03-2010   #4
MikeSalt has donated!
Check the battery voltage under load. With the engine turned off, turn on every single electrical item you can think of, and then measure the voltage. If it is significantly lower, then the battery has had it. I have a feeling that 12.6v on and unloaded battery is pretty low anyway, should be more like 13.0v for a healthy battery.
The good news is that you charging system seems to be working just fine with a running voltage of 14v.
MikeSalt is offline Reply With Quote Quote
(T) Starter motor problem solo3583 Idea 19 23-06-2013 23:20
(T) starter motor problem? Frosty 44 Multipla 6 01-11-2009 18:36
(G) starter motor problem pinkdolphin113 Punto (Mk2/2b) 5 02-04-2009 00:41
(T) Starter motor problem sutton Punto (Mk2/2b) 3 14-12-2008 13:10
(T) Starter motor problem shaun Punto (Mk2/2b) 7 09-03-2008 03:56
