Old 18-01-2005   #1
Punto MK2 Lowering
Hi, can anyone tell me if it is possible to have a Punto 53 lowered when 17" wheels have already been added ?
I have had the Front/Rear bumpers & sideskirts fitted and have also changed the original 14" for 17's.
I have asked 2 autofactor shops and both have told me I will be unable to have the car lowered unless I swap my wheels for smaller ones.
Can anyone tell me if and where I can get it done.
Nikki
LordyLord is offline Reply With Quote Quote
Old 18-01-2005   #2
Re: Punto MK2 Lowering
Yes you can. I just got my punto mk2 lowered 50mm on 17's, this was at SouthWest tyres. - Very good service.
pics on on here somewhere
Punto1.2_Motorsport is offline Reply With Quote Quote
Old 19-01-2005   #3
wolfracepunto has donated!
Is there a sticky about this in the Punto section? If not I think there should be
All mk2/mk2.5 Puntos can be lowered with 17s fitted. Anymore then 50mm though, there might be a -bit- of scrubbing when the car's heavy.
BMW 123d M Sport Auto
'10 Focus ST-3 Gone
Hornet 600 K8 Sold
wolfracepunto is offline Reply With Quote Quote
Old 19-01-2005   #4
Trader Rating: 10
dave has donated!
Quote Originally Posted by wolfracepunto
there is now
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 21-05-2005   #5
Ive got my mk2 lowered 35mm and it looks ok, but im really looking for a 50mm spring kit. Where did you purchase the 50mm springs (punto 1.2 motorsport)?? also how much were they to buy? cheers matey
punto urban racer is offline Reply With Quote Quote
Old 21-05-2005   #6
Im pretty sure the springs are made by PI, you can get them Here
a basic guide.
Fronts
Wheels off.
Car on axel stands.
Unclip any hosing from the strut (brake lines etc).
Disconnect any anti roll bars.
Get the bottom of the strut out of the hub housing (easier said than done on some cars- my Fabia Punto was easy).
Undo the bolts at the top of the strut- under the bonnet.
Take out the whole strut with spring.
Compress the spring and remove the bolt holding the spring in. This is usually dead tight so I got local Kwik Fit type garage with a whizzy gun to undo it for a fiver.
Swap springs over, cut bump stops (if required) and tighten up the top nut
Re-fit the whole unit back where it came from.
Backs
Get the car on axel stands, use a trolley jack and raise the trailing arm to take the strain off the shocks. Undo the bolt holding the shock on and lower the trolley jack slowly making sure brakelines arent being pulled down with it. The spring should come out on its own, but might need a spring compressor on it. Then stick the new spring in, trim the bumpstop and do everything back up!
Thanks AcerJak, JackFi, andydg, Mikey-D, Tris Harris thanked for this post
'10 Focus ST-3 Gone
Hornet 600 K8 Sold
Old 21-05-2005   #7
cheers wolfrace, nice one
Old 08-12-2005   #8
i also have mine lowered 50mm looks brill on 17's dude
black punto is offline Reply With Quote Quote
Old 09-03-2006   #9
w0w u guys who got urs lowerd 50ml must have a hard ride, mines lowered 40 with 17" wheels n thats hard enuff, a bit too hard, but its worth it for the look
sikwitit is offline Reply With Quote Quote
Old 19-08-2006   #10
hi ive done my girlfriends mk2 with custom made springs and thats on 17s with 3mm spacers on the rear and thats dropped 70mm at the rear and 60mm at the front and it looks ace took a bit of doin but well worth it tho mate
blue barron is offline Reply With Quote Quote
Old 04-12-2006   #11
ive got 17s on my mk2 but havent got round to lowering it yet. i was going to do it 40mm all round but someone told me it will scrub like a mofo and may need to get my arches rolled, etc bla bla bla! is he just being a pr*ck or is he right? also i was unsure weather to go for a full shocks and springs kit or just the springs, i know that just buying the springs will save me alot of money but wont my shocks give way after a while?
chris
puntobobmk2 is offline Reply With Quote Quote
Old 05-12-2006   #12
Quote Originally Posted by puntobobmk2
chris
You can drop it to 50mm and get a set of 17s on. You will need some wheel spacers 3mm maybe 5mm. You can use standard dampers but they will need replacing.
Steveo_BN is offline Reply With Quote Quote
Old 05-12-2006   #13
thats good to hear! but if i put 3 or 5mm spacers will my wheels rub on the arches, as they look kinda close already??
Old 06-12-2006   #14
There shouldnt be any rubbing might have a bit when the car is heavy. If you have alot of speed bumps in your area then a 50mm drop will be a killer.
Old 07-12-2006   #15
nice 1, ill get ordering the kit then and ill let you know how it goes. hopefuly smoothly, but nothing ever seems to be simple for me! thanks guys
lowering a mk2 punto 5 dr Lemzip Lets Talk FIAT 1 19-07-2004 06:48
Punto (Mk2/2b) reckon it needs lowering?? (mk2 punto) wolfracepunto Members Motors 12 05-05-2004 22:47
(S) Lowering a mk2 Punto Sporting Snoops Punto (Mk2/2b) 0 29-01-2004 20:41
punto mk2 lowering springs dave Auction Watch 0 25-01-2004 03:01
