Technical fuel leak
Technical fuel leak
vhan96
lincoln
Hi fuel leaking from pipe/pump on side of tank only when engin runing not sure wear from/wot to do thanks. ian:confused:
Hi, is it a mk1 punto? If the leak is just in front of the drivers side back wheel then most likely just the fuel filter leaking, £15 to buy maybe and a 10 min fit, if it's the pump thats a bit more expensive, but i don't know where they are on a mk1.
lift rear seat, undo the round metal plate--three screws-- you will see top of fuel pump, be very careful after a while the place where pipes connect become brittle and break off very easily, turn on engine you will see without disturbing anything if fuel leaking from here
agree with other posts; fuel filter most likely; often missed on service and exposed so corrode; easy to change as they have push on/off connectors that self seal when pulled off so you don't get petrol everywhere; it does mean lying down in the snow tho unless you have a nice heated garage with a pit like I have.........
Thanks for the replys will have proper look tomorow. It is a mk1 Ian:):)(y)
