hi all,
having a problem with the drivers side front lights. all of them excluding high beam are very very dim. the passenger side are fine and dandy and as bright as normal.
after a quick inspection one of the connectors to the casing of one of the headlights its very very corroded.
it has 2 black wires into one connector mounted on the metal housing of the bulb backing plate.
visible only when taking off the black plastic covers over the lights under the bonnet,
have read posts saying its a fuse or the earth, any one know what earth points and where to check.
