Thanks to the various posts in this forum that helped me fit my cam belt correctly. As a summary :-
Haynes state that the crankshaft should be put at TDC by aligning the crankshaft pulley with a shelf on the oil pump casting. This does not put the engine at TDC !
The correct way is to remove the rectangular rubber plug at the top of the bell housing (if it is still there) and set the crankshaft position using the flywheel marker. A mirror will be required as the coolant pipes obscure a direct view. This is shown in
https://www.fiatforum.com/attachment.php?attachmentid=50165&d=1221408885
Don’t do it using the method shown in the Haynes manual which is shown below
https://www.fiatforum.com/attachment.php?attachmentid=1500&d=1100539187
The camshaft is positioned as the Haynes manual.
You can verify TDC using a wire down a spark plug hole, this will show that the oil pump method is wrong. My old Mk1 and now my Mk2 have shown the oil pump method to be wrong, its not a matter of accuracy, its just in the wrong position.
Another thing to be careful of is to make sure you put the alternator pulley on correctly if not the little pin gets squashed, and the bolts don’t fit and the engine doesn’t work. Search for cambelt2 picture in the gallery for a further details.
The 1.2 8v is a non-interference engine (despite what the Haynes manual says) so the valves cannot hit the pistons when rotating the camshaft independently of the crankshaft.
