I've got a 1.2 8v mk2 punto and I was wondering if I can change the engine for a 1.2 8v out of a mk1 punto? i.e are they the same engine and will my wiring loom, ecu etc work. Cheers
ECUs are different (mk2 - Bosch, mk1 - Magnetti Marelli). Also 1.2 8v mk2 is Multi-Point Injection, whereas the mk1 is Single-Point Injection, so the throttle bodies and inlet manifolds are different. The blocks are the same, and pretty sure the heads are too.
