ok so i have just read this thread and just want to confirm that tdc is measured from the cam end bdc from gearbox end ive completely cocked mine up 1242 8v btw if i pull the crank up to tdc where does the cam have to be in respect to that ??what valves need to be where
cheers guys
lee
Before you curse at yourself for having cocked it up, check that the pip in the crank pulley is in the hole in the alternator pulley, or the ignition timing will be miles out.
TDC on compression on #1 cylinder (nearest the timing belt) is when the piston for that cylinder is at the top of its travel and both valves for that cylinder are shut -- the lobes (pointy lumps on the cam) will be pointing upwards.
