elastoplastscavenger
- Jan 19, 2009
- 21
- 4
hey folks, im a newb with a technical(ish) question:
The Heater on my 03 plate Punto JTD (1.9 litre, 85 ponies version) is not working as i would expect a car heater to work! I rarely have the heat setting bellow maximum, with the fan speed on number one, two or zero. I've had the car 3 months or so and only do long journeys. On my regular 90 minute motorway drive i usually only turn the heat setting or fan speed down (a little!) at about the half way point and that's while wearing my winter coat inside! Today, driving in a sleet shower, i was considering stopping to put on more clothes under my coat.
As for my techy(ish) fault finding: the thermostat appears to work well, the engine warms up as i would expect, the cooling circuit is filled and presurises, heater matrix is bled, the ventilation controls all appear to work fine and I do get some heat out the thing. Is this normal?
Having run two high mileage K reg Peugeot diesels, a smart ForFour petrol and a Land Rover Freelander diesel with a mixture of "engine" heated and electric heated cabins, the Punto is by far the worst heater i have come across by a long, long way.
as for a couple of other things with my new motor:
I dont have a key code. Is this gonna cause me problems in the future?
what is the difference between the 85hp JTD and the 100+hp JTD? My 85hp has an intercooler which was my first thought so is it a fancier turbo? engine management? DIY modificationable?
for a 5 year old car it is much rustier than i would expect. Underneath it looks more like my 10 year old peugeot. is that normal?
the service schedule says to check the valve clearances quite regularly...me thinks this isnt necessary so long as it isnt too noisy from the top end?
anyhoo, advice appreciated. Im quite handy with a socket set and multimeter.
