im Axle Specialists
Old 07-01-2009   #1
Exclamation punto 2001 1.2 fault codes p0202 p0352 and u1601
please help
i have just purchased a fiat punto 1.2 mia 2001, and having running problems
car is only running on 2 cylinders and engine light is permanently on
i have a code reader and 3 fault codes have appeared
p0202 - injector circuit open cylinder 2
p0352 - ignition coil b primary/secondary circuit
u1601 - this says this is 'pending' and check manufacturer
does anyone know what could be causing this
i have replaced the plugs and leads and there is a spark to the leads
someone please help
dazza6969 is offline Reply With Quote Quote
(T) fault codes fueltank Stilo 3 05-05-2009 21:15
(T) Punto 1.6 8V ECU Fault codes? andrewb Punto (Mk1) 4 26-03-2009 01:54
(T) How Can I Read Fault Codes On Mk1 Punto? jonnyfix Punto (Mk1) 3 21-11-2008 15:47
(G) Fault Codes Stevej Ulysse 2 29-01-2008 12:12
