ok, just worked out mpg accuratley using brimming as indicated by tris, and my mpg is 22.7! so there is something wrong, my dad's 2 litre 14 yr old toyota gets more than this.
suggestions?
suggestions?
suggestions?
191 miles, from 34 litres.....it is
suggestions??
what is MAF sensor??? thanks
i seeeee, i always wondered what that was, will check it tomrorow! btw what would happen if this was left disconnected at the air box?
it is usally in the area of the thermostate it should be a blue sensor... it has nothing to do with the gauge it tells the ecu when the engine is warm so it can adjust feuling for warm running if it is not reading currectly it thinks its on cold start and will use more fuel...
yeh, i guessed this wasnt meant to be lol, i saw it and it looks like a "pikey fix" might see if i can get a new one....but htis is just a breather hose innit?? not REALY important...ok so its not MAF, what next??? thanks
