bobbyt
I need to get at the speaker wire in the passenger door (its moved for some reason, now the leccy windows catching it when it goes down, causing problems).
Is there anything i need to know about removing the inside panel of the door. Is it just a case of removing a few screws, pulling the cover off and gently removing the clear water tight plastic?
Ta.
2000 1.2 very dodgey clutch judder punto.
Ta.
