Technical Allenkey for changing oil
joel
Stockholm, Sweden
Could anyone tell me which size the allen key to change the oil should be? I cant find anyone selling sets that have such big ones. The biggest are 10mm, which clearly is to small. Is it 14mm? I tried to meusure it but I want to be sure. I probely have to order it from somewhere, so it would be nice to order the correct size from the beginning :)
it's 14mm as far as i can remember. tool shops will sell them individually.
You really will need that big ratchet to get plenty of leverage, and while you're buying that key, get some axlestands as well. I would not get under my Punto Sporting without it.
BTW - it's a 12mm Hex Key, not 13 or 14
thanks for you help. I went to a DIY garage so it was easy to do. I noticed that my sump is rusty as hell. Is it easy to change it yourself? Or should I just ask the fiatgarage that does my service to change it with next oilchange?
wat would it be for a punto 55 s? 12 or 14mm, i need to change my oil and i cant get the exact measurement :(
