Thread Tools
Old 29-05-2004   #1
Replacing Dial Unit on MK2
Hi Guys,
I've got an MK2 Punto and it hasn't got a rev counter :( I know all of the dial units are the same size and im thinking of visiting a scrappy to pick one up!Has anyone replaced one and is it a problem to fit?
Will i need any extra cables to connect the rev counter up or should it work??
Dont know much about this so any help would be much appreciated!!
Thanks in advance
marky_20 is offline Reply With Quote Quote
Old 30-05-2004   #2
afaik the wire conector is the same on all models but i dont think that it would work.
i wouldnt recomend it but if you still want too go through with it you will lose your oddometer milage and the car will have to go to a garage too get calibrated (proxi alligned) too that unit else the display wont work properly.
uno 1.0ie RAAAWW!
kebab is offline Reply With Quote Quote
Old 30-05-2004   #3
I changed my dials about a month ago. there is one wire connection on the back and the dials are interchangable. everything should work fine (temp guage, revs etc) but you will need to have the mileage changed and the lcd display may well flash. these must be sorted out by fiat. they will charge you an hours labour to put mileage correct and stop flashing.... worth it though.
username is offline Reply With Quote Quote
Old 30-05-2004   #4
proxi alligning stops the lcd from flashing also with the diagnostic computer at a fiat garage you can only increase the oddometer.
uno 1.0ie RAAAWW!
Thread Tools
My First head unit install help! sradams1977 I.C.E 5 09-01-2004 15:57
head unit change has resulted in a problem thefishdude I.C.E 1 28-10-2003 03:38
(T) New Head Unit for 2000 Punto Puntosaplenty Punto (Mk2/2b) 1 07-10-2003 03:54
philips head unit medaluk I.C.E 1 06-07-2003 01:21
Modifying the AD185M head unit... Weekend driver I.C.E 3 10-04-2003 04:24
