Ok, i need some help on this as im getting sick of Fiat dealers, its going in for the 5th time on monday.
Heres the problem. (its a Punto Evo GP 1.4 8v)
Generally throttle response seems, lazy? I can blip the throttle quick and nothing will acctually happen but, at the moment i am working away from home and if i have a really good run home, once i come off the motorway the throttle will, what seems to, stick a little. When changing up through the box, the revs will continue to rise for maybe 2 seconds then hold for about a second then drop very slowly. The strange thing is, by the time i get back home, approx 10 miles from the motorway (approx 40% dual track, 60% town) the problem seems to go and return to 'normal' for this punto.
So far Fiat have done the following things;
Anyone else had this issue?? Has it been resolved?? At the end of my tether with this as its scaring the poo out off me at times as its just not slowing down!!!!!
- (Dealership bought from) Test drive - 'no fault found'
- (Dealership Bought from) after being dropped off by the AA - Diagnostics, Test drive in various manners - 'no fault found'
- (Dealership boought from) Same as above
- (Dealership near work) Test drives and Diagnostics - No fault found - Re-learned the throttle posistions
- (Dealership near work) test drives and diagnostics again - No fault found - Fitted brand new throttle body
