0 0453ST New member Joined Jun 8, 2019 Messages 10 Points 3 Mar 26, 2020 #1 Good night. I was wondering, and already tired of searching.. Someone can please tell me whats the ignition type or ignition System that the Punto HGT uses? And whats the probably of fitting an omex rev limiter..
H HgtBill Member Joined Jan 3, 2009 Messages 268 Points 96 Mar 26, 2020 #2 Are you asking about the trigger wheel spacings? If you are its an odd one, 97*,65*,10* before tdc. Look up information for a Subaru 6-7 as its the same crank trigger pattern but has a lot more support.
OP OP 0 0453ST New member Joined Jun 8, 2019 Messages 10 Points 3 Mar 26, 2020 #3 Noo :/ Im asking about the ignition system..
OP OP 0 0453ST New member Joined Jun 8, 2019 Messages 10 Points 3 Mar 26, 2020 #4 Ignition System.. Attachments Screenshot_20200326-013500.png 264.2 KB · Views: 58 Screenshot_20200326-013452.png 343.4 KB · Views: 53
H HgtBill Member Joined Jan 3, 2009 Messages 268 Points 96 Mar 27, 2020 #5 Okay, a bit of a vague question? Its one that sparks
N nitramtpr Patron member Parked in the garage Joined Aug 15, 2013 Messages 457 Points 165 Mar 31, 2020 #6 I think he's asking if it's a coil per spark plug or a single coil and HT leads to each spark plug.
N nitramtpr Patron member Parked in the garage Joined Aug 15, 2013 Messages 457 Points 165 Apr 2, 2020 #8 According to ePER it's a single coil per plug (number 5):
