JoeHatwell
- Joined
- Mar 7, 2019
- Messages
- 17
- Points
- 8
So I was having a bit of a fiddle with adding some footwell lights and decided I wanted them to come on and off when I open and close the doors. I now realise I should have connected to what in my car is the black and green wire but to start with I connected to the black and yellow being the constant 12v. Once I realised this I switched off the ignition and went to swap the leads over but I didn't realise that the feed hadn't yet switched off and the lights were still on so when I placed my soldering iron over the two black and yellow leads I had a small bang and a spark. Now I don't get a 12v feed therefore my original courtesy light isn't working. I've checked the 5amp fuse in the glovebox area that is what the fuse is for my car. I was wondering however if this fuse I found was for the switching circuit and not for the 12v feed. Is there another fuse somewhere that I could have blown or have I destroyed a circuitry component.
Cheers Joe
Tia
Cheers Joe
Tia
