solarjakee
- Joined
- Dec 10, 2017
- Messages
- 1
- Points
- 1
Hey there so I need to replace a fuel injector on my van and I've removed air intake manifold etc in order to gain access to it. From what I'm reading the next step is to disconnect the fuel pump relay in order to lower pressure in fuel lines but the problem is I can't find it.
Does anyone know how to identify the fuel pump relay, or have a diagram of the fuse box on a 2001 1.9TD? Or does anyone know if there's another way of lowering pressure to fuel lines in order to safely remove the injector? Or can the fuel injector on a diesel be safely removed without lowering pressure anyway?
Any help would be greatly appreciated. Cheers
