Lack off power at 2600/2700 RPM (bravo JTD 105)
A
André
I have a bravo JTD 105 with 285000km
The engine is running fine until last week the injector light went up by about 1 second and the car missfire.
The same hapen again this week and a friend of mine told me that may be a dirty injector.
So i put an aditive in the diesel to clead injectors and now driving pedal to the metal :)
The light is ok now but i notice slight lack off power only at +/- 2700rpm.
In the rest the engine is ok from 850rpm to 5000rpm
Can anyone help?
TNX
Time for a new MAF sensor :)
pop a new 1 on and all will be well :)
Tommy K - Have you got the Bottle!!
you only have a “hole“ in trat rpm region or all the way up to 5000rpm
sven
The MAF sensor have only 15000km
only have a “hole“ in that rpm region.
is it normal?
Have you changed the air filter, diesel filter?
Sounds like the same thing I had before I cleaned my EGR valve - there is a guide in the guide section
Or you can disable it
Members Site - - - - - - - My Site
Strongly disagree against disabling it. Avoid!
Either repair or replace.
Joske
Joske, the 105 has a vacuume one, you just plug in the vacuume pipe and all works like before ;)
No lights on the dash, because the ecu dosent pick it up
I have changed 2 week ago the air filter from stock to a K&N.
So this seem to be the problem right?
What shall i do now? relace with stock filter? :(
Leave it in - the ECU needs to relearn the new filter
Sven
S
2
437
Dark Lurker
C
1
514
K
C
2
515
Dark Lurker
M
7K
M
