Problem starter
Problem starter
A
Adam
I have a '99 Bravo 1.8hlx with an intermittent starting problem. It always starts but sometimes it starts immediately on the key, sometimes on the second go, sometimes on the sixth go. There is no rhyme or reason to it. It doesn't matter if the engine's hot or cold or what the weather's doing. Appart from this problem the car runs perfectly. My local Fiat garage say that they can't find anything wrong with it and they want to systematically replace sensors until they find the fault (at £53.00 ph). Can anyone help?
Kindred spirit!!!
Having the same sodding problem (see thread "what my garage said), I've done the fiat thing as well and same response "can't find anything wrong"
If you find out what is wrong please give us a bell.
And ill do the same!
doesn't start
Motor spins but doesn't seem to be trying to catch. If it sounds like it's trying to catch it starts immediately. If it doesn't sound like it's trying to catch it just turnsover and over until I turn the key back and try again - at which point it'll probably start!
Re: doesn't start
If you held the key for say 10 secs would it still not go?
Nope
If it doesn't sound like it'll start in the first millisecond I can hold the key for as long as I want but it won't go. If I turn the key again it'll probably start immediately.
Re: Yeeeeeesss
Cam sensor, they have a habit of not working well after a cambelt change.
Hmm
Ok how do I rectify the problem. Any idea of the cost to repair/replace.
Re: Hmm
Its behind the cam pulleys, basically its the same work as a new cambelt.
Re: Hmm
Ok this may sound silly, but I really dont know what this thing does.
So basicaly if this thing is "not working" it would cause the car not start but have the starter motor turn, but eventualy the engine will start.
and lastly is it spasmodic? in that sometime it works other times not!
Re: Hmm
It tells the ECU where the cam is so it knows when to spark the plugs. If the ECU doesn't know where the cam is it won't run.
J
1
380
Dark Lurker
W
659
wakka
W
T
1
570
Joseph
J
O
3
338
K
