Hi robfal,
I just replaced my blower motor 2 days ago.
You need to undo the bolt and disconnect the steering column from the shaft and move it between clutch & break padel.
You will see a black cover with 3 bolts and electrical connector.
Disconnect the electrical connector and unscrew the 3 bolts, the blower motor will be able to take out.
You just need to find the right parts to replace(Bravo has 4 to 5 types of blower motors, some resistor is build in and some is outside...).
I am very lucky to be able to find one that matches my in Singapore.
Now just want to find the wear out carbon bush to repair the old motor.
