Technical Remote Locking Drivers Side Only Fault
lannydagg
Hi
I have a 2006 plate punto grande. My central locking has decided to stop working on my drivers door. I can open the passengers side and boot but that's all. Has anyone got any suggestions what this could be?!
Thanks in Advance :)
If it makes no noises, then I'd start by taking the door card off and checking the solenoid.
Hi
Sorry. I have no idea what I'm looking for. It makes no noise what so ever :(
Ive not had the door card off myself, but they are all much the same.
remove the door card, take a look on or around the locking mechanism and you'll see what looks like a small electric motor.
It will be obvious, as it will have wires running to it.
There are a few on Fleabay if you need to visualise it, search "Grande Punto Central"
I'd start by checking the connections.
In all likelihood, its going to have 3 wires.
One for earth, one for open another for closed.
Check continuity on the earth, check for voltage on open and then closed.
If none of this makes sense, then you'll need to find help.
Good Luck
