Technical Instrument Cluster stopped working
BenzinaBrera
Hi guys, maybe you could help me, i have a Fiat Strada Pick Up 1.6 ELX, its a palio basically, anyways, the cluster started doing strange things, the fuel, temp and rev gauge would drop and come back up again at random times and now they decided to just stay off, i opened the cluster up but everything seems in order. is there any secret fuse, relay or harness plug i could check out on this car to see if its maybe a loose connection or blown fuse? i would rather think its a plug somewhere since the poor thing was operating in dusty environments a lot lately.
Quick summary:
-temp, fuel, rev counter gauges are dead
-cluster lights function
-speedometer and trip meter function
Any advice is appreciated :worship:
Kind Regards. :)
Hi, can someone please help me with advise on my Strada. Comercial
Cluster print keep burning, speedo meter and counter meter works but fuel temp and ref temp gage positive print keep on burning
Please can some one advise on help
Regards
no did not change anything and its not blowing bulbs or fuses, just burns the print (bord) circuit on the positive/feed side of the cluster. when the cluster circuit board burn( it burn on one track) then the fuel and temperature gauge, ref counter, alternator and oil lights don't work. this happen on a almost daily basis that it burn.
No it just randomly started doing this, and now keep on doing it, it just started doing this recently, I did not worked or do anything on cluster before, just now it stared doing this
herer is some pix
The body of the car rubbed thru one of the electrical tracks on the bottom side of the cluster , just bridge solder over it and cover to prevent it happening again.
Quick summary:
Kind Regards. :)
For Above ....
