hi all
i have a N reg cinq sporting with a slight bent hub on the nearside i could just replace with the same.
My question is does any other hubs fit eg punto hub fit a cinq?
i was thinking of different hub because i could then have better brakes with out hunting for uno turbo stuff and change the wheels for something with more grip easierly depending on what hubs i used.
eg. Is the punto sporting brakes better than the cinq's and would the whole hub bolt on?
i suppose it will be down to the bottom ball joint diameter and in turn can this be swopped from a punto? and would in increase (well, technically decrease) camber?
thanks
Ben
thanks
Ben
