wavestar New member Joined Jan 1, 2008 Messages 82 Points 31 Nov 25, 2009 #1 the manual says that if the rear hubs are removed / dismantled the bearings , nuts etc. have to be replaced. is this really necessary if they are ok ? I just want to replace the trailing arms
OP OP wavestar New member Joined Jan 1, 2008 Messages 82 Points 31 Nov 26, 2009 #2 how do you edit posts ? anyway what I should have said was it it necessary to renew the bearings and nut everytime the rear hub is taken off ? as per workshop manual.
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Nov 26, 2009 #3 Nut, possibly. Its a one shot type. They are not expensive to buy. I the bearings are in good enough order and don't spring apart when you go to change them over, then I would say no. Cheers SPD
