greenbriggs9
Hi guys, just bought a 93, 1.4 s ie Tipo, Nice to have a fiat again The only problem is, that when it is cold, it has an ever so slight knocking noise. It got noticable after i changed the oil? The problem completely goes away when warmed up, in fact it sounds dead quiet at higher revs. I had this problem with an Uno i use to own. Slight knock when cold, then gone when warm! Do you recon it could be the valve train, or a piston thats ever so slighty worn? I will live with it, and just take the cold engine easy, as one is suppose to anyways Any thoughts boys n girls???
