So here's the plan. Going to take the sump off tomorrow, remove the oil pickup and replace the base seal and then remove and clean the oil pressure relief valve. Followed by an oil pressure test and also a compression test. Just to check
I was definitely able to remove the inlet mabifold. I was able to refit mine with the motor in place and the main engine mount removed
