- Sep 14, 2009
- 19,492
- 3,294
Check the thread I mentioned in the previous post. The guy who has used B4s got springs from the same supplier.
Having just bought a set of rear B4s, I’m interested in the Fiat 500 rear springs. However, I see Shop4Parts lists several versions of the 500 rear spring. Anyone know which one I need for the 100HP please? And is there a part number for the top rubbers which I’ll need to fit at the bottom as well?
Looking forward to having a less bouncy Panda!
Dave, sorry to hijack someone else's thread but my recently acquired panda 100HP is sitting 15mm lower at the offside. Fitting the 500 rear suspension seems like a good start point but looking on eBay there are lots of models of 500 which one did you use or does it matter do you know.I'm repeating myself but using Fiat 500 springs at the back vastly improves the ride and the handling. They stop the back end skipping about on it's over-hard OEM springs.
The 2015 500 springs I used did drop the ride height but adding another spring top rubber cushion to the spring bottom solved that and also serves to protect the axle spring pans.
It was a dirt cheap mod. Good springs (much better than on the car) complete with rubbers cost me £10 each. What's not to like? IMO do it anyway the result is so good.
However, they are simple single rate springs. If you can get rising rate all around then ignore my twaddle.
My plan (if not going rising rate) would be Bilsteins on the front as suggested above with the rear end done with 500 springs and maybe Bilstein dampers, but the softer springs actually work well with OEM spec dampers.
Bump stops go Bilstein all around with shorter ones at the back. OEM are much too long and contribute to the harsh ride. If you dont like the additional body roll then fit an ARB. IMO that's not really needed but some may not agree.
Sorry AGAIN I should have read the full thread before commenting. I'll get some 500 springs ordered and once fitted report back.Dave, sorry to hijack someone else's thread but my recently acquired panda 100HP is sitting 15mm lower at the offside. Fitting the 500 rear suspension seems like a good start point but looking on eBay there are lots of models of 500 which one did you use or does it matter do you know.
Andy
Andy
You make an interesting point about Goodyear F1s.
I fitted them (actually got stuck with them) on an Audi A4 to replace the OEM Bridgestone Potenzas. To be blunt, the F1s ruined the car especially as I had specified Potenzas but the tyre fitters fitted the F1s leaving me over a barrel as I had to use the car. The issue was excessive noise, not something anyone would want on the Panda.
I've said before the General AltiMax works well on the 100HP for very reasonable money and they are good on road noise.
I also have 50 series tyres, I wonder if leaving the fiat 500 springs on but fitting longer bump stops would give a better ride, but hit the bump stop and not the tyre on the arch? Are 106mm long bump stops the standard length does anyone know? Current ones are 85mm long and as the tyre hits the arch trip before the bump stop hits makes them a bit pointless?I have 50 series tyres which will rub on the rear inner wheel arches. Longer bump stops will avoid the issue but it happens so rarely I prefer to have the better ride quality.
