This problem is driving me bonkers so if anyone has any advice, please let me know. I have a 2005 1.2 Panda which intermittently cranks over and takes a while to start whereas sometimes it'll start up first time no problem. This has been happening since before I had the battery replaced but has been worse since having it replaced. The garage are stumped and have tried everything from diagnostics to checking for battery drain, load testing the battery and cleaning sensors. An auto electrician plugged into the car and it came back with a key not recognised code. This problem occurs with both the remote key and spare and there seems to be no noticeable pattern concerning why it happens. It happens everytime I start the car although no fault lights are showing and the car run fine when it does start.
Do I need to get the keys or car recoded or is a diagnostic check by the Fiat dealer worth it first?
Any ideas you have would be great!
