lamlash
Hello,
I've had a problem with a persistent hesitation under load for quite some time in my 2006 Panda 1.2 Dynamic. I've done everything I can to try to troubleshoot the problem including replacing the following parts with new original equipment items:
Both coil packs
HT leads
Spark plugs
ECU (yes, I replaced the ECU)
The car runs perfectly otherwise and has new correct grade oil, genuine oil filter, air filter. The MIL lamp is off and there are no trouble codes.
I have checked for inlet manifold leaks.
There is no sign of head gasket trouble.
I have removed the injectors and had them cleaned and tested.
Today I checked the resistance of the throttle position sensor and found that it increases steadily as expected and then at about 3/4 throttle starts to drop again. Measuring resistance between the two outer pins I get the following readings:
Throttle closed (idle): 1760 ohms
Throttle 3/4 open: 2700 ohms (that's about the maximum reading)
Throttle fully open: 2250 ohms
Assuming the TPS is a normal potentiometer, it appears to be faulty. My questions are:
1. Does anyone have the correct resistance readings / specifications for this unit?
2. Is this likely to be the cause of the hesitation problem?
3. Can the TPS be replaced separately or am I looking at a new throttle body?
Thanks in advance for any advice you can offer
Both coil packs
HT leads
Spark plugs
