Thread Tools
Old 06-07-2010   #61
kipster1 has donated!
Re: Cold air feed for standard airbox
My current ram air system, just working on keeping the bonnet shut.
I did this on a Honda 90 about 30 years ago, the engine got a staple diet of flies, and a weak mixture just to make things worse .
Likes Shires liked this post
kipster1 is offline Reply With Quote Quote
Old 06-07-2010   #62
1985 AE86 Sprinter Trueno
trackdayqueen's Avatar
trackdayqueen has donated!
Liking it!
2008 Red Panda 100hp - Sold May 2011
trackdayqueen is offline Reply With Quote Quote
Old 13-01-2018   #63
Ireland
Holy Zombie Thread revival Batman ! If you run a 1.1 Eco( especially -or any 1.1/1.2 Panda) , gutting the plastic 'walls' / 'dividers' inside the air box and cutting away the blanking plate ( seriously Fiat ?!) behind the perforated air intake in bumper help greatly in throttle response / acceleration ( and probably mpg at a steady cruise ) .Just be very careful you don't leave any plastic debris/ dust in these to get sucked into intake ( use good strong Stanley knife , hacksaw blade/ sander / sandpaper , Hoover etc to get the job done ) The obvious fear of increased likelihood of water getting in doesn't seem to have materialised despite lots of motorway journies behind lorries in torrential rain and driving through floods etc .Fiat really strangled the lovely old 1108cc FIRE engine in the Eco taking about 2 seconds off 0-60 time with this nonsense .Of course they went to far with the Fiat 500 1.2 but that's another forum !
ytareh is offline Reply With Quote Quote
Old 13-01-2018   #64
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
The amount of broken picture links in this thread is exactly why externally linked images are discouraged
Thanks varesecrazy thanked for this post
Likes Most Easterly Pandas, jrkitching liked this post
Eklipze3k is offline Reply With Quote Quote
Old 13-01-2018   #65
varesecrazy has donated!
@robjnr wants to log back in to their hosting account.
On the FIAT forums hosting this isnt an issue
Old 13-01-2018   #66
Moderator
Quote Originally Posted by ytareh View Post
Modifying the airbox will make absolutely no difference whatsoever to performance, acceleration or economy except when the engine is running at wide open throttle, so cruise mpg won't change at all (unless you cruise flat out!).
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 13-01-2018   #67
Quote Originally Posted by jrkitching View Post
Quite agree - it probably sounds more urgent though.
Likes jrkitching liked this post
babbo_umbro is offline Reply With Quote Quote
Old 13-01-2018   #68
Ireland
I was working on assumption that if car could go faster or had a tiny bit more bhp it would use less fuel at same speed .Then again I guess using that logic Ferrari’s would get 100 mpg
Old 13-01-2018   #69
Moderator
Think about it; the ECU controls the amount of fuel injected according to the amount of air that's flowing into the engine (OK, it's a bit more complex than that, but it'll suffice to illustrate the point). Except when the throttle is wide open, the air flowing into the engine is restricted by the butterfly valve (that's how the power output from the engine is controlled) and will be less than the airbox system is capable of delivering. Improving airflow through the airbox just means the butterfly valve doesn't need to open so much for any given airflow through the engine; the airflow needed for any given power output remains the same, so the fuel injected will be the same as well. It's only when the butterfly valve is fully open that improving breathing through the airbox will increase the absolute power available.
Thread Tools
(T) Cold Air Feed cash_123 Punto (Mk2/2b) 27 09-01-2008 14:40
(T) Cold air feed chegers Cinquecento / Seicento 26 16-10-2007 15:44
(G) Cold Air Feed Newboi Cinquecento / Seicento 8 26-02-2006 19:21
(T) Cold air feed... arc Cinquecento / Seicento 10 19-09-2004 00:55
(T) Cold Air Feed. carlloughney Bravo / Brava 5 04-06-2004 02:43
