- Mar 5, 2008
- 32
- 8
I don't know if this has been covered before or not.
But here is the scope:-
Every now and then particularly when the car has been left sitting for a while when opening the door there won't be that buzzing noise of the gearbox pump activating. When the car starts and you engage any gear, it will state on the dash "Gear Not Available" and then "Gearbox Failure"
Twice while the car is in motion it will again for no reason show "Gearbox Failure" but it will remain in gear and you can continue driving it, once straight away after it showed the message, I tried pulling to the side, the gearbox then functioned like normal. Another time, I pulled over to the side, stopped the car and it went into Neutral and continued displayed Gearbox Failure.
Sometimes, after 2-3 minutes I try it.......... it will work again. Other times after a day it will work again.
Does anyone know what is on the way out?
