behind the bulb holders is probably a loom,
running well inside the dashboard,
1st check to see if it's the bulb to holder contacts that are at fault,
easiest is to swap 2 x fitted bulbs,
if the fault is still on the same holder then investigate further the contacts of that holder..or flex the cable / loom Behind it to see if that in itself can interrupt the supply,
charlie
