- Jan 10, 2016
- 54
- 14
Just taken my 2013 1.2 Panda Pop to have its headlight recall, and asked the garage to check the sump to confirm my suspicions.
Which they did - sump pan leaking as it has rusted through and requires replacement, for the princely sum of £232.70. Apparently very unusual to occur at just over 4 yrs old, which I guess is a change from "They all do that, sir"
Not entirely convinced after a quick google, but only had the car 3 months so no idea if anything the previous owner did may have contributed.
Anyone done this job? In theory looks pretty straightforward - there's nothing in the way on a Pop, and the I guess the key will be torqueing up the bolts gradually and evenly to make sure the joint is oil tight, plus use of decent "gunk" and gasket.
Also pointed out that the rear shock absorber bushes are shot - only £220 for these. Having replaced shocks and springs on my daughter's 169 a couple of months back, I'll definitely be doing that in house.
