Hi, does this mean that in normal mode, if your front wheels lose a bit of grip then grip is transferred to rear - say for example a slippery roundabout or bend (and then presumably put back to front bias when grip is ok: grip being determined by differing speed of wheels from sensors) i.e. drive transferred but wheels not electronically braked to adjust...
And in ELD (if I understand it) the system actively brakes spinning wheels and will transfer more power (up to half I think?) to the rear ... all "decided" by the cars system.
I'm not clear as to whether power is constantly fed in and out depending on grip in either mode - I presume so. So if driving easily on for example fresh snow on the flat you might be in front wheel drive,
until the system detects any front wheel slipping... (so no such thing as a "stick it in 4 wheel drive and leave it" setting like old land rovers or subarus where it was purely mechanical coupling putting drive to the back (or front for landies)
Any hoo... seems to work from what I've seen... yet to try it!
some info from car magazine.co.uk
The Panda’s torque-on-demand drive system features two differentials and an electronically controlled coupling, channelling torque front-to-back and side-to-side, helping to quell understeer, pull back oversteer and send drive to whichever tyres have the most traction. Layered on top of this is what Fiat calls an ‘electronic locking differential’, essentially the traction control system intelligently trimming wheelspin from individual wheels – this can be turned off on demand.
