Old 02-08-2021   #1
Will it fit? SE101C distributor onto 1000CL
Hi all,
Just a quick question confirming if this part will fit onto my engine before I order it! Looking to switch from points to electronic distributor after my points distributor shook itself to pieces (canít do a conversion, need to start from scratch).
My 1988 Panda 1000CL had a Marelli S181A distributor on it and Iím looking to replace it with a Marelli SE101C, extracted from a 4X4 Sisley. Is that compatible with my 1000CL?
Thanks all
Avspotter is offline Reply With Quote Quote
Old 02-08-2021   #2
Working Seicento at last!
firstcar-Y10's Avatar
Trader Rating: 1
firstcar-Y10 has donated!
Re: Will it fit? SE101C distributor onto 1000CL
If it's the breakerless one with the module then yes, but it would be helpful if you can get the wiring from coil to dizzy too as the connectors are different. Coil is different too but easy enough to buy separately
THE MIGHTY GRUMBLEWEED
firstcar-Y10 is offline Reply With Quote Quote
Old 03-08-2021   #3
I Void Warranties
Dragon Man's Avatar
Dragon Man has donated!
its really simple.. with the old distributor you just have the one green wire.. but the new distributor you have the same wire and an ignition live input. simple.
heres one i made earlier..
the wire feeding the ignition coil is an ignition live so just attach the orange wire to the same terminal on the coil.
Thanks Avspotter thanked for this post
Dragon Man is offline Reply With Quote Quote
Old 03-08-2021   #4
thanks all for your replies - I'll update once the part is installed!
Likes Dragon Man liked this post
Old 31-08-2021   #5
Thank you to everyone who contributed to this thread. The distributor does indeed work and I'm getting a lovely strong spark through the leads. Just had to get the proper coil as the simple barrel coil wasn't compatible.
Likes firstcar-Y10 liked this post
(G) Panda 1000CL Philler Panda (Classic) 1 18-02-2015 21:08
Panda (Classic) 1000cl dave Auction Watch 0 16-04-2013 22:49
(G) 1000cl panda-power Panda (Classic) 3 18-09-2007 20:35
(G) Panda Distributor will this fit? Ruaraidh Panda (Classic) 5 28-05-2007 20:33
(G) 1000cl Kris007 Panda (Classic) 2 14-06-2005 11:27
