Thread Tools
Old 09-09-2019   #1
Trader Rating: 1
Low compression on all cylinders
This actually happened months ago, but only had a chance to look into it now.
My '91 Panda 4x4 was running a bit poorly then it stalled and wouldn't start. It was getting fuel, it had a spark, and and was turning over well - so I was confused.
At last I had a chance to look at it today and so I started with a compression test. All the cylinders were around 20 to 30 psi. After a google, I thought it was maybe fuel washed. So I added a little engine oil to each cylinder and disconnected the fuel. Compression remains low, maybe 5psi more with the oil. Surely oil would have revived the compression a little more?
Any ideas what is wrong? The engine has been idling poorly for sometime so I quite often run with a little choke to stop stalling at lights is town. Could I have flooded, fuel washed the cylinders and worn out the piston rings? On all 4 cylinders???
I'm also thinking the carb might be at fault for the not starting and may need a service, but that doesn't help the compression problem.
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
Chrysler Voyager
nitro_warrior is offline Reply With Quote Quote
Old 09-09-2019   #2
Trader Rating: 1
Giacosa has donated!
Lunar Lander 2 Champion
Re: Low compression on all cylinders
Hey Nitro. Been a while. The HG was my 1st thought but again you'd expect some difference between cylinders. Has it overheated at all.
Giacosa is offline Reply With Quote Quote
Old 11-09-2019   #3
panda1408 has donated!
I'd verify the compression tester is reading correctly first!
1988 Panda 4x4 Sisley
1982 Panda 45
panda1408 is offline Reply With Quote Quote
Old 11-09-2019   #4
Working Seicento at last!
firstcar-Y10's Avatar
Trader Rating: 1
firstcar-Y10 has donated!
Quote Originally Posted by panda1408 View Post
Most things that'll cause a loss of compression are unlikely to affect all the cylinders simultaneously. even reading usually means you're OK. Maybe cam timing? belt slipped a couple of teeth?
Or wildly speculating - cam lobes worn. Didn't you have an issue with wear on the fuel pump drive? maybe that's not the only bit that wasn't getting properly lubed.
THE MIGHTY GRUMBLEWEED
firstcar-Y10 is offline Reply With Quote Quote
Old 12-09-2019   #5
Trader Rating: 1
Hi guys, good to be back on the forum, been a while! Thanks for the suggestions.
A bit more info. I actually did question the compression tester and replaced it for a better one. I checked it on my air compressor too and the readings matched so I think the compression tester is good.
A few years ago (er at least 7...) I replaced all the valve stem seals, ground the valve seats and replaced the head gasket. It ran ok after that. Though I don't think compression has ever been that great (I hazily recall 70-90 from the last time)
Thinking aloud. For there not to be compression it has to be either
  1. Head gasket
  2. Piston Rings
  3. Valve seats
Have I missed anything? Any other ways of checking the above items?
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
Chrysler Voyager
Old 12-09-2019   #6
Trader Rating: 1
Or cam timing. If you've got valves opening out of time you could finish up with less of an inlet charge or exhaust valves opening early, either of which might give you less, but even compression as it will affect all cylinders. Your oil in the bores check would make no difference in that case either. Did you check the cam timing as part of your initial fault finding?
Old 13-09-2019   #7
Trader Rating: 1
Cam timing, yes missed that in your first post. That is a good call. My timing belt is embarrassingly old too.
Another piece of the jigsaw... at the time I was getting spark, getting fuel but the engine was turning over really easily. I remember thinking it didn't feel right, which supports to the low compression readings and the sudden change would give weight to the timing belt jumping... might be on to something...
I have a late summer holiday next week but will take a look at the cam timing when I get back.
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
Chrysler Voyager
Old 29-09-2019   #8
Trader Rating: 1
Might be on to something here. See pictures. Timing is a long way out. A surprising amount. I would have thought one or two teeth at most, but the cam shaft is a good quarter turn out of position! Is that normal for a timing belt slipping?
I will order a new belt install and check the pressure again. Thanks for steering me in presumably the right direction!
***EDIT***
When cleaning the timing cover I spotted there was wear on the inside. Definitly some untoward timing belt action been happening!
Likes firstcar-Y10 liked this post
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
Chrysler Voyager
Old 30-09-2019   #9
Trader Rating: 1
Always nice when you go looking and find a "smoking gun". Hope the replacement sorts it.
Old 30-09-2019   #10
Trader Rating: 1
portland_bill has donated!
Timing belt will slip if belt becomes slack. Tensioner might be failing, or more common, water pump bearings. A failing water pump will slacken the belt tension.
Whilst the belt is off it is a false economy not to replace the pump.
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 01-10-2019   #11
I Void Warranties
Dragon Man's Avatar
Dragon Man has donated!
re-time it up and see if it runs.. lets face it, you cant do any damage to this engine if the belt snaps all together. none interface engines for the win!
also if you run it without the cover on, you can see what the belt is on with
Dragon Man is offline Reply With Quote Quote
Old 01-10-2019   #12
Trader Rating: 1
I replaced the water pump not so long ago - couple of years (and didn't replace the belt! ) so hopefully the pump is still ok. Very much the school of thought of non-interference no problem!
Will take a look at the pump and the tensioner whilst i'm replaceing the belt.
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
Chrysler Voyager
Old 07-10-2019   #13
Trader Rating: 1
Got a chance to replace the belt and fix the timing yesterday.
Changed the tensioner bearing too - it was knackered, and running dry. I left the water pump as it is actually quite new.
Ran the vacuum test again. 100 psi on cylinder 1, good. 15 psi cylinder 2 and 3, not so good. Back to 100 psi on cylinder 4. Headgasket then.
A quick strip down revealed the gasket had blown between 2 and 3.
Good double whammy of issues. I suspect the engine was running for a while with the blown gasket, I imagine a blow between 2 and 3 doesn't make a huge difference as the cylinders are in phase. Then a combo of lumpy firing and a worn tension bearing threw the timing.
Hoping I've got away with with just a new gasket, the head and block look like they should be ok after a clean up.
Also got a slight crack on the exhaust manifold - just the flange for one of bolts to connect to the exhaust. Take it 4wd manifolds are the same as 2wd?
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
Chrysler Voyager
Old 07-10-2019   #14
Trader Rating: 1
Just been looking at exhaust manifolds and spotted this on ebay
STAINLESS STEEL RACE DECAT DE CAT EXHAUST MANIFOLD FOR FIAT 500 PANDA 1.2 09-13
Aside from the difference in the down pipe. Would this fit to the head? The bolt pattern and gasket look the same. Looks like quite a tempting option to make fit, or spur me on to my often contemplated stainless exhaust...
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
Chrysler Voyager
Old 07-10-2019   #15
Trader Rating: 1
Without the catalytic converter, MOTs might be a problem.
Panda Alessi
Thread Tools
(G) No Low Compression Mark 123 Stilo 3 27-11-2017 12:34
(T) Zero compression on two cylinders Silent Chris Punto (Mk2/2b) 7 06-10-2015 22:48
(G) No compression on 3 cylinders garethslee Punto Evo 13 05-05-2014 14:21
(T) No compression on 2 cylinders, options? antipesto93 Punto (Mk2/2b) 3 13-10-2013 22:22
(G) Low Compression chris.fulton Punto (Mk2/2b) 6 11-01-2007 14:24
