Hi all,
I bought some new seals for my mk1 master cylinder (not the mk2 readily available online) from Brake Parts UK (linked below) - an Autofren Seinsa kit:
https://brakeparts.co.uk/.../Hydraulic.../BMS1237
The seal pictured from the primary cylinder is FAR too tight, such that the piston fails to retract once pressed in by the brake pedal (takes about 10 minutes to reset itself it the brakes released position). You can see the small nick taken out of it from when I removed the piston - it's so tight it tears itself apart each time I remove the piston, so I'm reluctant to fiddle with this all much further. It needs an extreme amount of force from me to manually remove it due to the tight seal. Even after lubricating the seals and bore with brake fluid, there was no improvement once the piston was in (presumable because the seal was so tight it dried itself out by wiping fluid off).
I was wondering if anyone else had experienced this problem with overtight seals once they'd replaced them, and if you had been able to do anything about. Or any other ideas I could try to relieve the "tightness" of the seal, without compromising the cylinder.
These are the right seals as they are specified for the mk1 cylinder with 19mm bore, but I'm a little stuck here with it!
Cheers all
H
Cheers all
H
