Albert Alfvag
Member
Hello everyone. So it's that time of year again when I bring out the tools to work on my pandas. Winter in sweden is not the best time to work on cars.
So, I have a 1988 panda 4x4. Last year was spent fixing the brakes, some rust and making it run on idle. I never drove it last year though and never have so long as I've owned it.
The other day I took it out just to let it run for maybe a kilometer.
I noticed how the temperature gauge went up to 90 degrees and beyond just on that short drive. When I got back and opened the hood, some water pipes were extremely hot while others were cool. This doesn't seem normal to me.
So my thought was as follows: maybe the cooling system is blocked somehow, preventing the flow of coolant through the engine. And my second thought was: maybe the water pump is broken.
Question:Is there any good way to check if the system is blocked? And is there an easy way to see if the pump is working (maybe disconnect some hose and see if the coolant comes under preasure when I turn the engine over)?
Sorry for the long text but I like to explain things clearly.
Best regards,
Albert
Best regards,
Albert
