FIAT Auto Specialist Team
Old 12-09-2013   #1
pooroldcodger has donated!
brake pads
I want to take the brake pads out of my Panda (M Reg 999cc) but I can't figure out how to get the "wedge-shaped" blocks out. Does anybody have any advice and / or a picture? The picture in my Haynes doesn't seem to look much like my set up!
pooroldcodger is offline Reply With Quote Quote
Old 12-09-2013   #2
Trader Rating: 2
aquamarine has donated!
Re: brake pads
Hi, don't have a pic to hand I'm afraid, but:
There are two small retaining clips which fit through the wedge shaped blocks. Pull them out (pliers job) - one comes vertically up, the other vertically down.
Tap the wedges out (tapping towards the outside of the car). I use a hammer and a tough old screwdriver to drive them out.
Will be much easier with a pic - will try to find one!
Good luck, David
Likes AndyPanda4x4 liked this post
aquamarine is offline Reply With Quote Quote
Old 12-09-2013   #3
Re: brake pads
Thanks David. The two small retaining clips - do you mean the 2 small "R" clips?
If so, I have found those (under the general crud!).
Ok so it's just a case of knocking them out. I thought it must be but I didn't want to wade in with the hammer without checking!
There is also a big rusty (in my case anyway) spring type clip . Is that to stop the pads from rattling?
Old 12-09-2013   #4
Alixcompo has donated!
Re: brake pads
When I recently did discs and pads on the Terra van I thought about a photo diary but then reckoned no one would be interested.
If I get a chance I'll pull them down again and get some pics
Thanks pooroldcodger thanked for this post
Alixcompo is offline Reply With Quote Quote
Old 13-09-2013   #5
Trader Rating: 1
portland_bill has donated!
Re: brake pads
Quote Originally Posted by pooroldcodger View Post
Yep, two small "R" clips. Pull them out, keep them safe. Drift the wedges out and the caliper will wriggle out. The big spring clip is to keep it all tight and prevent rattling.
Check the surfaces of the caliper and the wedges. Clean them well and if in good condition smear with as little copper grease as possible on the sliding surfaces. (Whilst lubricating and preventing rusting, the copper grease will attract dust.) If available, graphite on the sliding surfaces works better as it does not attract dust. If in doubt get new wedges.
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
(Tu) Brake pads Stifler3513 Grande Punto 8 04-04-2013 20:02
(T) Seem to be going through brake pads... SouLz Punto (Mk2/2b) 32 03-07-2012 15:21
(G) New brake pads lemonjelly Ducato 0 01-07-2010 13:34
(G) Brake Pads? Ian_Dublin Punto (Mk2/2b) 1 03-06-2005 00:31
