Good evening all! I hope you have been having a most excellent weekend but now I must quiz those who have had a bit more experience with carburettors!
Basically the fuel in the carb is boiling from the heat of the engine. If you put your ear to it you can hear it bubbling and its forcing fuel out into the inlet through the accelerator pump jet and maybe other places too. This means I stop the car after a journey and it slowly pours fuel into the manifold which makes it bloody hard to restart!!
Now I can think of 2 things that might help:
Disconnect the heated manifold pipes from the coolant system ( not sure this will help as the heat will surely still ride up the manifold with conduction anyway - temperature might be greater without the coolant system flow?)
Build a heat shield round the carb from aluminium or something ( the exhaust and inlet are both on the same side on this engine (Y10 Turbo) so heat from exhaust and turbo might be getting to the carb by radiation.
Anyone else have any more suggestions? Anything you can buy to cool a carb?
Cheers,
Si
Cheers,
Si
