I didn’t get any pics of changing the valve stem oil seals sorry
All it took was pulling / chiselling the old ones off and pushing the new ones on and home with a 10mm deep reach socket.
Grinding in the valves is a slow job but well worth the time and effort.
The first pic is of the valve with the crap cleaned from it and ready to be ground in.
The second pic is me grinding the valve into place. All you need is a valve grinding tool, sounds really flash but all it is, is a dowel with a sucker on the end, the same tool you use to lift the guides out. Stick the valve onto the sucker, apply the grinding paste and with the valve in place apply a little bit of downward force and twizzle the dowel between your hands. Use the coarse paste first then the fine one.
The third pic is of the ground valve all nice and smooth like. You should use an engineers marker to check the seat but I didn’t have any so used the soot from a paraffin lamp as you would a gun mechanism to ensure the valve and seat were all ground in. if any marker / soot remain after you twizzle the valve in the seat then you need to grind a bit more.
Do that for all the valves. Great job to do in front of the TV, took me 2 pints and an episode and a half of the gadget show (minus the adverts)
Next put it all back together. Pics 4 to 9 are the valve bits going back in.
Pics 10 and 11 are how the collet pins go into place on the valve stem.
Pic 12 is a line up of the ground in valves next to their seats.
Pics 13 and 14 are of the valves all back in place with springs.
Pic 15 is the re assembled head ready to check the clearances.
:yum:
