Now I've been thinking of this for a while as a possible project. I'm mainly after idea's and a bit of info.
Dad's 1000CL's engine has seen better day's (poorly maintained by previous owners ) and I've been thinking of buying a written off mk3 Diesel (MJ) Panda .
Now how easy would it be to convirt the 1000CL to Diesel.
Obviously I'd need different fuel pumps and electronics etc, but I'm more on about how easy engine fitment would be.
I know the mk3 Petrol Panda's still use the FIRE engines fitted to mk2's, and would assume at a rough guess that the engine mount points would hopefully be the same
On this assumption, I would also assume that if designing an engine from new (the 1.3 multijet) that they'd do it so that the mounting points are the same as the petrol versions so that they don't have the redesign the engine bay in the mk3's that much
(still with me so far )
So is it likely that as far as mounting goes, the MJ would be a fairly straight swap from the 999cc FIRE?
Any Idea's would be great.
Jon.
Jon.
