Old 02-07-2004   #1
weber carb info
i have a weber 30 32 dmte 30/150 from a 1.1 uno, i am going to try and use this in place of the weber 32 tlf on my panda.
i have had an adapter plate made to mount the carb but i need to know what the cylindrical sensor with the wire attatched is, could this be the anti flood device?i also need to know where the vac pipe from distributor goes and what the other pipe stubs are for.
my carb only has one vac pipe inlet and the anti flood device, but the uno carb has exta ones but could it be posssible to run with what i need and blank of or link up tne extra ones?
david connell
panda racer is offline Reply With Quote Quote
Old 02-07-2004   #2
There is a good "Haynes" book about carbs which gives a lot of information about specific types, how they work, how to repair them, and different jets/emulsion tubes used when the same one is used in different cars.
The sensor with the wire might be fuel cut off to prevent run-on.
John H is offline Reply With Quote Quote
Old 17-03-2017   #3
Hungary
Re: weber carb info
Quote Originally Posted by John H View Post
Sounds nice, would be usefull for me! Could you link it for us, Sir?
gtasomogyi is offline Reply With Quote Quote
(T) fitting carb to fiat tempra 1.6ie andycash Tempra 7 19-11-2004 09:09
(G) panda weber 32 tlf jetting panda racer Panda (Classic) 10 29-06-2004 03:02
(T) carb and water mrf94 Cinquecento / Seicento 5 11-08-2002 20:57
