Hi I'm new to the forum so hello to everyone. I live in N.W. UK. Thanks to everyone in the forum in advance.
My son who knows nothing about cars bought a panda 750 J reg on ebay, low mileage (25K), but unfortunately very very very very rusty around all the wheels, brakes discs, drums hubs and all suspension. It had been stood a long time .(He didn't really know what to look for and unfortunately was away from home so I couldn't check it out)
The front brakes are all seized, I need to replace the pads, callipers, discs and some brake pipe. Unbelievably the solid brake pipe going from the master cylinder to the flexible hose burst through corrosion (near where it goes through the wing) It had been MOT't 5 months earlier. Fortunately I was driving and no one was killed, my son was on the motorway driving the car the previous day!!!
I have removed TWO bolts (one bolt and one nut) holding the calliper holder but it wont move so I cant replace the disc. Do I need to undo something else? The Haynes just says unbolt and remove!
Is it possible to buy the small metal parts which the callipers slide on (the ones you knock out before removing the calliper)? They are very corroded and although cleaned are damaged by rust.
What size are the brake fittings on the pipe ends? I can't separate the rest of the pipe from the flexible its all gnarled up now and stuck, so prob need new flexis too (although they look ok apart from corroded ends)
Also the disc shield has disintegrated on the drivers side , anybody know where I can get one and how it's fitted please?
Finally (well for the moment anyway) is there an adjusment to control the amount of fast idle when the choke is used? There's a cam but I cant see any adjustment apart from the idle speed adjustment screw on the throttle cam. (In other words I want it to idle faster when the choke is used)
That's about it for now- I cant drive it anywhere 'till it has brakes!
thanks again in advance
woz
woz
