Yes, BUT, you have to use the ring gear from the 1300 (four speed 180mm clutch) flywheel and press it onto the 1500 (five speed 190mm clutch) flywheel you want to use, so the starter will engage ... inner diameter is the same for both ring gears so it's a simple job.
SteveC
