Hello
I am new to online forums. I have a 1995 Fiat Barchetta. It needs some work ?
We have removed the gas tank which seemed to be filled with crud it looks like coffee grinds in molasses. We clean the inside of the tank using paint thinner and then using Pine-Sol and hot water the tank came spic and span clean however when we rinsed it out with cold water there was new spots that looked like rust but don’t seem to be rust. Is there some sort of coating on the inside of the gas tank?
Now I’m not sure what to do. Should I just put the tank back in the car and fill it up with gas and hope for the best or should I take us somewhere to have it professionally cleaned and sealed?
I am also looking for a new set of gas tank seals as the one that was in it doesn’t look the best. I have ordered a new pump already.
I am in Nova Scotia Canada
