Old 26-08-2018   #1
Argentina
Hi All , Fiat Avventura, Nice to meet you all . I need some technical help around the world from Fiat owners . Am having Fiat Avventura
Fiat Avventura is my carClick image for larger version
ID:	193573Click image for larger version
ID:	193574Click image for larger version
OneWorldOneSky is offline Reply With Quote Quote
Old 27-08-2018   #2
Argentina
Re: Hi All , Nice to meet you all . I need some technical help around the world from
ID:	193588Click image for larger version
This is the Exact Problem . Front wheel Fender gap is different in both the wheels . Left side is perfect , but right side is having gap
Old 27-08-2018   #3
varesecrazy has donated!
Re: Hi All , Fiat Avventura, Nice to meet you all . I need some technical help around
Hi.
Give it a little push-apply pressure.
It is probably loose..
Conventionally the shield is slotted into several other components. Then retained with clips / screws.
Check for empty holes.. where screws are missing.
We do not get your model in the UK.. but I own 2 x GrandePunto.
They are derived from the same GeneralMotors product (astra D)
Charlie
Old 27-08-2018   #4
Argentina
Hi Charlie ,
Thank you for your reply.
I got your point. Is this normal ?, the gap between two front tyres . Onside is two fingers gap and right side ( driver side 4 finger gap) .
Can you just kindly look your front side wheel clarification.
Thank you
Old 27-08-2018   #5
You’d need to post better pictures, of the whole wheel in the whole wheel arch to be able to see what is going on for sure, but in essence either the wheel is in the wrong place because the wheel alignment has been knocked out, or the bumper has been knocked out of place.
We never got the avventura here, this car was specifically built for areas with poor roads, at the end of the day it’s a normal punto with the suspension jacked up, however this makes it more liable to suspension damage as it’s not really an off roader so not built to take much abuse
Maker and voice behind the YouTube channel PuntoHowTo 12k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 28-08-2018   #6
Argentina
Quote Originally Posted by AndyRKett View Post
Youíd need to post better pictures, of the whole wheel in the whole wheel arch to be able to see what is going on for sure, but in essence either the wheel is in the wrong place because the wheel alignment has been knocked out, or the bumper has been knocked out of place.
We never got the avventura here, this car was specifically built for areas with poor roads, at the end of the day itís a normal punto with the suspension jacked up, however this makes it more liable to suspension damage as itís not really an off roader so not built to take much abuse
Hi ,
Thank you for your reply .
I will update the the Picture asap.
Problem Facing : 1. while driving right side wheel is jumping and .
2. Car is pulling to right which is wheel have Extra Gap.
3 . While Reverse the car on perfect land or flat area without touching the Steering automatically moving to right . And the same I have tried fully turned the steering to left and took reverse, but again automatically turn to the right side.
Thank you.
Old 28-08-2018   #7
You have a failed component.
Something is physically loose.
This needs investigating NOW..!!
Old 28-08-2018   #8
Argentina
Quote Originally Posted by varesecrazy View Post
Hi Charlie,
Thank you for reply.
Yes something weird in front wheel, last week itís damaged my Right wheel disk plate. I have changed last week .
Yes i will go with local mechanic. Till now I have done company service, but they are lazy and Fiat South India manager saying ď This Fiat Design , which is one side more gap and one side is less ď lol
I was shocked when he replied like that. And stopped believe the Fiat Service Center. So today searched whole google and found out a Fiat local Mechanic with Five star background. God will help in this issue to sort it out the man made machine.
Thank you
Old 28-08-2018   #9
Quote Originally Posted by OneWorldOneSky View Post
Hi Charlie,
Thank you
quite possibly a related issue
these are the parts likely to be at fault
http://eper.fiatforum.com/eper/navi?...D=1&GUI_LANG=3
they tie the position of the front wheel hub ( that the wheel attaches to)
Idea..
carefully Place a wheel wrench on the head of a wheel securing bolt ( there are 4..) apply "tightening pressure"..
load the pressure on the Left hand front wheel,
see if the wheel moves around in the wheel-arch ( the gaps you have shown)
then do the same with the Right Hand wheel
if there is anything badly worn / broken .. you should be aple to replicate the movement with hand force.. from the wrench.
this is how I discovered damaged rubber mountings in the suspension arm of my FIAT
do let us know what you find.
Cardiff / Oxford
Old 29-08-2018   #10
Argentina
Idea..
Hi Charlie,
From the shared website link , I have changed first 2 picture parts, third one sway bar , anti roll bar and that shield is not changed . I will there with local mechanic this weekend Saturday to identify.
Will ramp the car and check . I will take pictures to compare.
Thank you
Old 29-08-2018   #11
Argentina
ID:	193687. This the new 4 layered Fiat Avventura body cover which will protect all whether. 100 % water resistant and Proof.
Best part is water never stick on this cover like lotus flower. High grade but little bit costly.
Old 17-09-2018   #12
Argentina
Attachment 193588Attachment 193589
Hi all,
Any one have same issues like in my car.
Old 01-04-2019   #13
Argentina
Left Side Gap between fender is perfect
Old 01-04-2019   #14
Argentina
ID:	199159Click image for larger version
Old 01-04-2019   #15
Argentina
Hi Anyone see the difference? Right side and left side wheel gap between fender
